Ga door naar hoofdinhoud
IBM ThinkPad T42 Display Replacement
Wat je nodig hebt
  1. IBM ThinkPad T42 Display Replacement, Bottom cover: stap 1, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Display Replacement, Rear screws: stap 2, afbeelding 1 van 1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: stap 3, afbeelding 1 van 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Display Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T42 Display Replacement: stap 4, afbeelding 2 van 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: stap 5, afbeelding 1 van 2 IBM ThinkPad T42 Display Replacement, Bezel Removal: stap 5, afbeelding 2 van 2
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  6. IBM ThinkPad T42 Display Replacement, Display Screws: stap 6, afbeelding 1 van 1
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: stap 7, afbeelding 1 van 1
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Austin Kidd
317 Reputatie
3 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
37 handleidingen geschreven
2Gids Commentaar
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - Antwoord
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 38
Altijd: 13,543
