Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its screen.
Onderdelen
Geen onderdelen opgegeven.
  1. Close the screen and turn the closed laptop over.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. Remove the extra RAM cover, by lifting where the screw was and pulling out.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. Turn the laptop right side up and open the screen.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. Close the laptop and turn it over.
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. Unscrew the five screws that were hidden by the stickers.
    • Unscrew the five screws that were hidden by the stickers.
  7. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  8. Turn the computer right side up and open the screen.
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  9. Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  10. Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
  11. Push apart the retaining clips.
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
  12. Pull the wireless network card out.
    • Pull the wireless network card out.
  13. Close the computer screen.
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
  14. Open the laptop screen.
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
  15. Remove a single screw from the metal plate that secures the display cable.
    • Remove a single screw from the metal plate that secures the display cable.
  16. Pull the metal plate away from the display cable.
    • Pull the metal plate away from the display cable.
  17. Disconnect the display cable.
    • Disconnect the display cable.
  18. Carefully pull up the long antenna cables that were attached to the wireless network card.
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
  19. Lift out the screen.
    • Lift out the screen.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Marissa Blustein
481 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-8, Maness Spring 2010 Lid van Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Leden
26 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 17,941
