Ga door naar hoofdinhoud
IBM ThinkPad T30 Wireless Card Replacement
Wat je nodig hebt
  1. IBM ThinkPad T30 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 3 IBM ThinkPad T30 Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 3 IBM ThinkPad T30 Wireless Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before starting, make sure to have the Think pad turned off and the power supply is closed.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: stap 2, afbeelding 1 van 3 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: stap 2, afbeelding 2 van 3 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: stap 2, afbeelding 3 van 3
    • Focus on the panel at the center of the Thinkpad.
    • Unscrew the three 4mm Phillips #0 screws that bind the panel cover to the Thinkpad.
    • Lift the panel from the right edge and remove the panel.
  3. IBM ThinkPad T30 Wireless Card Replacement: stap 3, afbeelding 1 van 3 IBM ThinkPad T30 Wireless Card Replacement: stap 3, afbeelding 2 van 3 IBM ThinkPad T30 Wireless Card Replacement: stap 3, afbeelding 3 van 3
    • Before removing the wireless card, identify the three wires that need to be removed.
    • The first two wires that are on the bottom right can be easily unplugged with your fingers by pulling on the white label that comes with the wire.
    • For the last wire on the center right, use a plastic opening tool to pry out the wire.
  4. IBM ThinkPad T30 Wireless Card Replacement: stap 4, afbeelding 1 van 3 IBM ThinkPad T30 Wireless Card Replacement: stap 4, afbeelding 2 van 3 IBM ThinkPad T30 Wireless Card Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to pry the hinges on the side of the wireless card. These hinges hold the wireless card in place.
    • The wireless card will pop up at an angle, and can then be easily pulled out.
    • When reinserting a new wireless card, insert the card at the angle that it popped out. Then simply push the card down to lock it back into the hatch.
Conclusie
Alex Kost
271 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-20, Amido Fall 2012 Lid van Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Leden
16 handleidingen geschreven
Één opmerking
I f i take out this component will the computer act normally The computer has a car diagnostic program installed as an after thought as i wish to be normal computer Do i just remove and ever thing okay thanks Terry
Terry Dollery - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 5,362
