Ga door naar hoofdinhoud
IBM ThinkPad T30 Optical Drive Replacement
Wat je nodig hebt
  1. IBM ThinkPad T30 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before starting, make sure to have the Think pad turned off and the power supply is closed.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Optical Drive Replacement, Optical Drive: stap 2, afbeelding 1 van 1
    • Locate the 4.8mm Phillips #0 screw on the far left of the ThinkPad, closest to the edge and above the battery, and unscrew it with a Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Optical Drive Replacement: stap 3, afbeelding 1 van 2 IBM ThinkPad T30 Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • On the side of the ThinkPad, locate a lock next to the optical drive. Use your fingernail to slide the lock to the right.
  4. IBM ThinkPad T30 Optical Drive Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T30 Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Once it is unlocked, a small tab will pop out. Pull on the tab with your fingers.
    • The optical drive will easily slide out. Remove the optical drive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Kost
271 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-20, Amido Fall 2012 Lid van Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,972
