Ga door naar hoofdinhoud
IBM ThinkPad T30 Hard Drive Replacement
Wat je nodig hebt
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Hard Drive Replacement: stap 3, afbeelding 1 van 3 IBM ThinkPad T30 Hard Drive Replacement: stap 3, afbeelding 2 van 3 IBM ThinkPad T30 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T30 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: stap 5, afbeelding 1 van 2 IBM ThinkPad T30 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
Conclusie
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 andere personen hebben deze handleiding voltooid.
Allie Knauer
90 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-20, Amido Fall 2012 Lid van Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Leden
16 handleidingen geschreven
Één opmerking
good description and photos..thanks :]
David - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 56
Altijd: 19,028
