Inleiding
This guide will show you how to replace your display from your laptop. You would need to replace it if you break your display.
Wat je nodig hebt
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Remove the plastic part attached to the bottom of the screen.
Gently pull it from one side and then from another.
Één andere persoon heeft deze handleiding voltooid.
