Ga door naar hoofdinhoud
IBM ThinkPad 560z Keyboard Cover Replacement
Wat je nodig hebt
  1. IBM ThinkPad 560z Keyboard Cover Replacement, Upper Case: stap 1, afbeelding 1 van 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Cover Replacement: stap 2, afbeelding 1 van 2 IBM ThinkPad 560z Keyboard Cover Replacement: stap 2, afbeelding 2 van 2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Cover Replacement: stap 3, afbeelding 1 van 2 IBM ThinkPad 560z Keyboard Cover Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Cover Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad 560z Keyboard Cover Replacement: stap 4, afbeelding 2 van 2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Cover Replacement: stap 5, afbeelding 1 van 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Cover Replacement: stap 6, afbeelding 1 van 2 IBM ThinkPad 560z Keyboard Cover Replacement: stap 6, afbeelding 2 van 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Cover Replacement: stap 7, afbeelding 1 van 1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Cover Replacement: stap 8, afbeelding 1 van 2 IBM ThinkPad 560z Keyboard Cover Replacement: stap 8, afbeelding 2 van 2
    • Carefully lift and remove the keyboard.
Conclusie
Derek Driscoll
119 Reputatie
8 handleidingen geschreven
Cal Poly, Team 26-27, Regan Spring 2010 Lid van Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,800
