Ga door naar hoofdinhoud
HyperX Stinger Ear Cup Replacement
Wat je nodig hebt
  1. HyperX Stinger Ear Cup Replacement, Ear Cup: stap 1, afbeelding 1 van 1
    • Unplug your headset.
  2. HyperX Stinger Ear Cup Replacement: stap 2, afbeelding 1 van 1
    • Firmly grip the old ear cup/cushion.
    • Pull the end of the ear cup foam until the bottom lip is released from the ear cup mount.
  3. HyperX Stinger Ear Cup Replacement: stap 3, afbeelding 1 van 3 HyperX Stinger Ear Cup Replacement: stap 3, afbeelding 2 van 3 HyperX Stinger Ear Cup Replacement: stap 3, afbeelding 3 van 3
    • Slide the ear cup upwards to remove it.
    • Repeat steps 2 and 3 on the other ear cup.
  4. HyperX Stinger Ear Cup Replacement: stap 4, afbeelding 1 van 1
    • Align the top lip of the replacement ear cup on the mount.
  5. HyperX Stinger Ear Cup Replacement: stap 5, afbeelding 1 van 3 HyperX Stinger Ear Cup Replacement: stap 5, afbeelding 2 van 3 HyperX Stinger Ear Cup Replacement: stap 5, afbeelding 3 van 3
    • Pull the foam slowly over the mount.
    • Align the ear cup with the end of the mount, and then release, ensuring that the pad is securely attached to the mount.
    • Slowing down is necessary in this step to avoid over stretching the foam and damaging it.
  6. HyperX Stinger Ear Cup Replacement: stap 6, afbeelding 1 van 1
    • Gently press the ear cups to the mount to make sure they are properly seated.
    • Repeat steps 4 through 6 for the other ear cup.
    • Test the headset to ensure the new ear cups are comfortable and secure.
Eindstreep
Philip Reyes
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 291
