Ga door naar hoofdinhoud
HyperX QuadCast S Mute Sensor Replacement
  1. HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: stap 1, afbeelding 1 van 3 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: stap 1, afbeelding 2 van 3 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: stap 1, afbeelding 3 van 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Mute Sensor Replacement: stap 2, afbeelding 1 van 3 HyperX QuadCast S Mute Sensor Replacement: stap 2, afbeelding 2 van 3 HyperX QuadCast S Mute Sensor Replacement: stap 2, afbeelding 3 van 3
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
  3. HyperX QuadCast S Mute Sensor Replacement: stap 3, afbeelding 1 van 3 HyperX QuadCast S Mute Sensor Replacement: stap 3, afbeelding 2 van 3 HyperX QuadCast S Mute Sensor Replacement: stap 3, afbeelding 3 van 3
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan Arruda
711 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Lid van UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 Leden
9 handleidingen geschreven
2 opmerkingen
Nice guide, but I've been unable to find a replacement.
Is the tap sensor from the Quadcast (the non-S version) compatible?
P S - Antwoord
I believe it should be compatible. The S version should just be different with its illumination and USB charging so the tap-to-mute sensor should be the same. Unfortunately, it's hard to source replacement parts since hyperx does not sell them separately. I could only recommend buying a used hyperx microphone for cheap and scraping the parts for replacement. Hope that helps.
Nathan Arruda - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 146
Altijd: 2,453
