Ga door naar hoofdinhoud
HyperX CloudX Flight Charging Port Replacement
Wat je nodig hebt
  1. HyperX CloudX Flight Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 1
    • Place the device on a flat surface and orient the ear cups towards yourself.
  2. HyperX CloudX Flight Charging Port Replacement: stap 2, afbeelding 1 van 2 HyperX CloudX Flight Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Gently pull around the perimeter of the left ear cup until the cushion is fully removed.
  3. HyperX CloudX Flight Charging Port Replacement: stap 3, afbeelding 1 van 1
    • Use a small Phillips screwdriver to remove the base plate.
  4. HyperX CloudX Flight Charging Port Replacement: stap 4, afbeelding 1 van 1
    • After removing the plate, locate the charging port on the board. You can carefully desolder the charging port from the board by pointing the tip of your soldering iron to melt the existing connections.
Conclusie
To reassemble your device, follow these instructions in reverse order. Ensure to carefully resolder the USB port as to not interfere with other connections.
Één andere persoon heeft deze handleiding voltooid.
Santiago Rojas
291 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 63
