Ga door naar hoofdinhoud
Husqvarna Viking Designer 1 Needle Replacement
Wat je nodig hebt
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: stap 1, afbeelding 1 van 2 Husqvarna Viking Designer 1 Needle Replacement, Needle: stap 1, afbeelding 2 van 2
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: stap 2, afbeelding 1 van 3 Husqvarna Viking Designer 1 Needle Replacement: stap 2, afbeelding 2 van 3 Husqvarna Viking Designer 1 Needle Replacement: stap 2, afbeelding 3 van 3
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: stap 3, afbeelding 1 van 1
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: stap 4, afbeelding 1 van 2 Husqvarna Viking Designer 1 Needle Replacement: stap 4, afbeelding 2 van 2
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: stap 5, afbeelding 1 van 1
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: stap 6, afbeelding 1 van 2 Husqvarna Viking Designer 1 Needle Replacement: stap 6, afbeelding 2 van 2
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: stap 7, afbeelding 1 van 1
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: stap 8, afbeelding 1 van 1
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
Conclusie
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Excellent illustration!!!
KO SAMUEL TAK SHUN - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 41
Altijd: 1,278
