Ga door naar hoofdinhoud
Huffy Kids Tricycle Seat Replacement
Wat je nodig hebt
  1. Huffy Kids Tricycle Seat Replacement, Seat: stap 1, afbeelding 1 van 2 Huffy Kids Tricycle Seat Replacement, Seat: stap 1, afbeelding 2 van 2
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: stap 2, afbeelding 1 van 2 Huffy Kids Tricycle Seat Replacement: stap 2, afbeelding 2 van 2
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: stap 3, afbeelding 1 van 3 Huffy Kids Tricycle Seat Replacement: stap 3, afbeelding 2 van 3 Huffy Kids Tricycle Seat Replacement: stap 3, afbeelding 3 van 3
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: stap 4, afbeelding 1 van 3 Huffy Kids Tricycle Seat Replacement: stap 4, afbeelding 2 van 3 Huffy Kids Tricycle Seat Replacement: stap 4, afbeelding 3 van 3
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: stap 5, afbeelding 1 van 3 Huffy Kids Tricycle Seat Replacement: stap 5, afbeelding 2 van 3 Huffy Kids Tricycle Seat Replacement: stap 5, afbeelding 3 van 3
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: stap 6, afbeelding 1 van 2 Huffy Kids Tricycle Seat Replacement: stap 6, afbeelding 2 van 2
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
Conclusie
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
Babatunde Adewunmi
222 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 588
