Ga door naar hoofdinhoud
Huawei P7 Screen Assembly Replacement
Wat je nodig hebt
  1. Huawei P7 Screen Assembly Replacement, Front Display Assembly: stap 1, afbeelding 1 van 1
    • Cracked screen, but no idea how to start?
    • Keep calm
    • Follow my guide
  2. Huawei P7 Screen Assembly Replacement: stap 2, afbeelding 1 van 3 Huawei P7 Screen Assembly Replacement: stap 2, afbeelding 2 van 3 Huawei P7 Screen Assembly Replacement: stap 2, afbeelding 3 van 3
    • Heat the glass panel on the back to around 85°C so the adhesive loosens
    • Use a plastic spudger or opening tool to gently pry up the glass
    • Carefully work your way around the edges
    • Be careful at the bottom. There is a flex cable running near the back-glass
    • Never use metal tools for this. Metal will scratch the black paint off the backplate
  3. Huawei P7 Screen Assembly Replacement: stap 3, afbeelding 1 van 3 Huawei P7 Screen Assembly Replacement: stap 3, afbeelding 2 van 3 Huawei P7 Screen Assembly Replacement: stap 3, afbeelding 3 van 3
    • First, we'll disconnect the battery cable
    • Use a philips screwdriver to remove the shield, revealing the battery connection
    • Next, disconnect the LCD/Digitizer ribbon
  4. Huawei P7 Screen Assembly Replacement: stap 4, afbeelding 1 van 2 Huawei P7 Screen Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery
    • Use plastic tools to pry the battery off its adhesive
    • Patience is key here
    • Don't bend, puncture or heat the battery.
  5. Huawei P7 Screen Assembly Replacement: stap 5, afbeelding 1 van 2 Huawei P7 Screen Assembly Replacement: stap 5, afbeelding 2 van 2
    • Heat the front side to about 85°C
    • Using a plastic tool, seperate the display from the frame, but don't pull it too far away.
  6. Huawei P7 Screen Assembly Replacement: stap 6, afbeelding 1 van 2 Huawei P7 Screen Assembly Replacement: stap 6, afbeelding 2 van 2
    • Flipping the phone over, we can see the display ribbon
    • Make sure none of this cable is stuck to the frame
  7. Huawei P7 Screen Assembly Replacement: stap 7, afbeelding 1 van 2 Huawei P7 Screen Assembly Replacement: stap 7, afbeelding 2 van 2
    • Pull the display ribbon through the frame
    • Make sure there is not a single glass-shard left on the frame. Any little splinter will cause significant damage to the new screen you're about to place
  8. Huawei P7 Screen Assembly Replacement: stap 8, afbeelding 1 van 2 Huawei P7 Screen Assembly Replacement: stap 8, afbeelding 2 van 2
    • Tape up the whole frame with double-sided tape for a perfect fit that won't come loose
    • Make sure you don't cover important holes
    • Put the new screen in, sliding the cable first, making sure the whole cable (aswell as the little part sticking out)
  9. Huawei P7 Screen Assembly Replacement: stap 9, afbeelding 1 van 2 Huawei P7 Screen Assembly Replacement: stap 9, afbeelding 2 van 2
    • As good as new
Conclusie
- Never use metal opening tools
- Remove ALL the glass splinters from the frame before re-attaching the new one
- Have fun
26 andere personen hebben deze handleiding voltooid.
Maxim
2.297 Reputatie
3 handleidingen geschreven
iFixers Belgium Lid van iFixers Belgium
Business
1 Lid
5 handleidingen geschreven
12 opmerkingen
Hallo Paintskill,
Ich habe eine wesentliche Frage. Was muss ich noch beachten, wenn mein Display und das Touchpannel ganz ist und ich aber nur mein Deckglas austauschen möchte. Wie sind diese aneinander geklebt? Wie schwierig ist das?
Und ja, welche doppelseitigen Klebestreifen hast du benutzt?
lg und Danke,
Friendly
Friendly - Antwoord
Hallo,
Nun ich habs auch selber versucht und wollte sagen.
Mein Deckglas war nur gesprungen, nicht das Display. Also wollte ich daran sparen und nur das Deckglas kaufen. Keine gute Idee... Das ist brutal mit einander verklebt und selbst wenn man es abbekäme müssten wir das empfindliche Display noch vom Kleber reinigen. Das hab ich mit nicht geschafft - und ich war im Labor der Hochschule. Kauft gleich das Display ^^
lg
Friendly
PS: die 85°C zum Kleber aufheizen sind ganz vernünftig.
Friendly - Antwoord
found nice video about this process here: https://www.youtube.com/watch?v=BD24da5b...
Karel - Antwoord
I like that helping video.Thanks pal!
Styleart -
I like that helping video.Thanks!
Styleart -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 42,920
