Ga door naar hoofdinhoud
Huawei Y300 SIM Card Replacement
Wat je nodig hebt
  1. Huawei Y300 SIM Card Replacement, Rear Cover: stap 1, afbeelding 1 van 3 Huawei Y300 SIM Card Replacement, Rear Cover: stap 1, afbeelding 2 van 3 Huawei Y300 SIM Card Replacement, Rear Cover: stap 1, afbeelding 3 van 3
    • Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
    Is the battery of huawei y300 the same with huawei y336?
    Timothy Agub - Antwoord
  2. Huawei Y300 SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery with your finger up and out to remove the battery for replacement.
  3. Huawei Y300 SIM Card Replacement, Replace The Battery: stap 3, afbeelding 1 van 1
    • After the battery is removed, replace the battery
    • Make sure the battery sits correctly by locating the power output at the bottom left.
  4. Huawei Y300 SIM Card Replacement, SIM Card: stap 4, afbeelding 1 van 1
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Anthony Ng
1.433 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G3
4 Leden
8 handleidingen geschreven
Één opmerking
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 4,748
