Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone. Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone. Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
    • Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
  2. Lift the battery with your finger up and out to remove the battery for replacement.
    • Lift the battery with your finger up and out to remove the battery for replacement.
  3. After the battery is removed, replace the battery
    • After the battery is removed, replace the battery
    • Make sure the battery sits correctly by locating the power output at the bottom left.
  4. Remove the SIM card by sliding it upwards.
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Anthony Ng
1.425 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G3
4 Leden
4 handleidingen geschreven
Één commentaar
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 3,837
