Inleiding
In this guide we are going to replace the LCD display on the Huawei ascend Y300 android smartphone. This may be necessary for a damaged screen causing lines, dark spots, and distorted images. The damage may be caused by:
- Physical impacts/pressure
- Heat
- Moisture
- Dust
Before we start it is a good idea to prepare an organized area and a bowl or tray to put the small screws in and prevent them getting lost to carry out the repair.
Wat je nodig hebt
Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
Lift up and remove the battery.
There are two more ribbon cables at the top that must also be disconnected, to do this simply lift them up from their connecter with the tweezers or with the spudger.
it's important to add that lateral flat cable can be lift up only after turning up the rotating switch which is on the lower side.
just did some edits to this repair guide fixing that issue, the edits are just waiting to be verified, sorry about the poor image quality in the new step 6 best I could do with only 2 hands and a OnePlus One camera.
44 andere personen hebben deze handleiding voltooid.
2 opmerkingen
good
it a good advise and easy
Its really helpful and so easy ... thanks
