Inleiding
Repairability assessment of the Huawei Watch GT, performed July 2019. The model assessed is a black stainless steel FTN-B19.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
The plastic rear cover of the Huawei Watch GT is secured by 4 Torx T3 screws (3.6 mm length).
Applying an opening pick or fingernail to the small notch at the upper edge of the watch is enough to separate the bottom cover.
At this point it's possible to open the watch but the display and back cover are still connected by a multi purpose interconnect flex cable.
Ambiq Micro Apollo3 Blue MCU with ARM Cortex-M4 Processor
Winbond 1 Gbit serial NAND flash
NXP 80T35 36 04 SSD902, probably NFC controller
Broadcom BCM47752 GPS receiver
The Huawei Watch GT earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
Watch band replacements are fast and simple.
Easy glueless opening procedure.
The battery can be removed independently. The removal procedure needs some prying but isn't too bad.
The screen and the digitizer can't be removed separately.
The sensor assembly including the vibration motor is soldered to the back cover.
6 Opmerkingen
do you have any idea where i can buy the spare part for the screen?
I got mine fell, and the screen gradually becoming pitch black. Now it’s completely black, but i think all the other functionalities are okay.
The screws in step 3 are not phillips does anyone know what they are?
Hi Mauricio,
thanks for your comment. Your objection was right and we made a correction in the repairability assessment. The screws securing the rear cover are Torx 3 (T3) screws.
They are y shape micro driver, torx I think, look like a Philips from the side but if you look directly down its in a Y or Mercedes car badge (emblem) shape. Pick them up quite cheep from screwfix or toolstation.
Hello,
Thank you for this write up. Do you know how many o-rings if present are sealing the buttons? Or is it a diaphragm seal type for the actuation?
Very Best Regards,
James H.
