Ga door naar hoofdinhoud
Inleiding
Repairability assessment of the Huawei Watch GT, performed July 2019. The model assessed is a black stainless steel FTN-B19.
  1. Huawei Watch GT Repairability Assessment, Huawei Watch GT Repairability Assessment: step 1, image 1 of 3 Huawei Watch GT Repairability Assessment, Huawei Watch GT Repairability Assessment: step 1, image 2 of 3 Huawei Watch GT Repairability Assessment, Huawei Watch GT Repairability Assessment: step 1, image 3 of 3
    • Exterior reference photos.
  2. Huawei Watch GT Repairability Assessment: step 2, image 1 of 3 Huawei Watch GT Repairability Assessment: step 2, image 2 of 3 Huawei Watch GT Repairability Assessment: step 2, image 3 of 3
    • Two spring bar pins attach the watchbands to the body and allow for easy removal.
    • Reference shots of the front and back of the Huawei Watch GT body.
  3. Huawei Watch GT Repairability Assessment: step 3, image 1 of 3 Huawei Watch GT Repairability Assessment: step 3, image 2 of 3 Huawei Watch GT Repairability Assessment: step 3, image 3 of 3
    • The plastic rear cover of the Huawei Watch GT is secured by 4 Torx T3 screws (3.6 mm length).
    • Applying an opening pick or fingernail to the small notch at the upper edge of the watch is enough to separate the bottom cover.
    • At this point it's possible to open the watch but the display and back cover are still connected by a multi purpose interconnect flex cable.
  4. Huawei Watch GT Repairability Assessment: step 4, image 1 of 3 Huawei Watch GT Repairability Assessment: step 4, image 2 of 3 Huawei Watch GT Repairability Assessment: step 4, image 3 of 3
    • We go by the book and unplug the battery first by removing two Phillips #00 screws (2.9 mm length) and a metal shield.
    • The battery is held in place by mild adhesive and comes out after some gentle heating and prying.
  5. Huawei Watch GT Repairability Assessment: step 5, image 1 of 2 Huawei Watch GT Repairability Assessment: step 5, image 2 of 2
    • Unplugging the interconnect cable—carrying the vibration motor and the heart rate sensor—requires removing another pair of screws and a small metal shield.
    • Seems like the interconnect flex cable can't be removed from the rear cover—bummer.
  6. Huawei Watch GT Repairability Assessment: step 6, image 1 of 3 Huawei Watch GT Repairability Assessment: step 6, image 2 of 3 Huawei Watch GT Repairability Assessment: step 6, image 3 of 3
    • After removing four more Phillips #00 screws and disconnecting the screen and digitizer connector as well as the side button cable, the motherboard can be removed.
    • The flex cable of the two side buttons is glued to the motherboard with mild adhesive and can be peeled off.
  7. Huawei Watch GT Repairability Assessment: step 7, image 1 of 3 Huawei Watch GT Repairability Assessment: step 7, image 2 of 3 Huawei Watch GT Repairability Assessment: step 7, image 3 of 3
    • Ambiq Micro Apollo3 Blue MCU with ARM Cortex-M4 Processor
    • Winbond 1 Gbit serial NAND flash
    • NXP 80T35 36 04 SSD902, probably NFC controller
    • Broadcom BCM47752 GPS receiver
  8. Huawei Watch GT Repairability Assessment: step 8, image 1 of 1
    • The screen and digitizer of the Huawei Watch GT are glued to the display frame with strong adhesive and can not be removed without causing damage to them.
    • So replacing the screen means replacing the complete top part of the watch.
  9. Huawei Watch GT Repairability Assessment: step 9, image 1 of 2 Huawei Watch GT Repairability Assessment: step 9, image 2 of 2
    • The Huawei Watch GT earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
    • Watch band replacements are fast and simple.
    • Easy glueless opening procedure.
    • The battery can be removed independently. The removal procedure needs some prying but isn't too bad.
    • The screen and the digitizer can't be removed separately.
    • The sensor assembly including the vibration motor is soldered to the back cover.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
129.344 Reputatie
534 handleidingen geschreven
iFixit Lid van iFixit
Community
148 Leden
15.457 handleidingen geschreven
9 Opmerkingen
Hi Dominik,thanks for your share!
This article about HUAWEI WATHCH GT teardown is the second I’ve ever seem,and the other is there : 集微拆评 . Combine the two,you’ll found that all the ICs installed on the PCB is clear.
Roc - Antwoord
do you have any idea where i can buy the spare part for the screen?
I got mine fell, and the screen gradually becoming pitch black. Now it’s completely black, but i think all the other functionalities are okay.
Ridho Akhiro - Antwoord
The screws in step 3 are not phillips does anyone know what they are?
Mauricio Flores - Antwoord
Hi Mauricio,
thanks for your comment. Your objection was right and we made a correction in the repairability assessment. The screws securing the rear cover are Torx 3 (T3) screws.
Dominik Schnabelrauch -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 53
Afgelopen 30 dagen: 259
Altijd: 13,111
