Inleiding
If your audio is muffled or distorted on your Huawei SnapTo G-620, then the speaker may need to be replaced. Use this guide to replace the speaker on your SnapTo.
Wat je nodig hebt
Remove the back cover.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
Bijna klaar!
Conclusie
