Ga door naar hoofdinhoud
Huawei Pronto LTE Display Screen Assembly Replacement
Wat je nodig hebt
  1. Huawei Pronto LTE Display Screen Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 Huawei Pronto LTE Display Screen Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
  2. Huawei Pronto LTE Display Screen Assembly Replacement: stap 2, afbeelding 1 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 2, afbeelding 2 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
  3. Huawei Pronto LTE Display Screen Assembly Replacement: stap 3, afbeelding 1 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 3, afbeelding 2 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 3, afbeelding 3 van 3
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Huawei Pronto LTE Display Screen Assembly Replacement: stap 4, afbeelding 1 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 4, afbeelding 2 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 4, afbeelding 3 van 3
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
  5. Huawei Pronto LTE Display Screen Assembly Replacement: stap 5, afbeelding 1 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 5, afbeelding 2 van 3 Huawei Pronto LTE Display Screen Assembly Replacement: stap 5, afbeelding 3 van 3
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
  6. Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: stap 6, afbeelding 1 van 2 Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: stap 6, afbeelding 2 van 2
    • Remove the motherboard. Refer to the Motherboard Replacement Guide.
    • Remove the battery.
  7. Huawei Pronto LTE Display Screen Assembly Replacement: stap 7, afbeelding 1 van 2 Huawei Pronto LTE Display Screen Assembly Replacement: stap 7, afbeelding 2 van 2
    • Once the battery is removed the screen will be visible.
Conclusie
Crystal Edwards
450 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 72
