Ga door naar hoofdinhoud
Huawei Phone p7 Power Flex Replacement
Wat je nodig hebt
  1. Huawei Phone p7 Power Flex Replacement, Power Flex: stap 1, afbeelding 1 van 3 Huawei Phone p7 Power Flex Replacement, Power Flex: stap 1, afbeelding 2 van 3 Huawei Phone p7 Power Flex Replacement, Power Flex: stap 1, afbeelding 3 van 3
    • Remove back cover.
  2. Huawei Phone p7 Power Flex Replacement: stap 2, afbeelding 1 van 2 Huawei Phone p7 Power Flex Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers or some tools thin and sharp to cut the adhesive between power flex and bracket. And then pry it up and remove it.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sophia
43.810 Reputatie
62 handleidingen geschreven
2 opmerkingen
When you say follow the steps in reverse to finish the repair, what exactly happens with the glue melted in the first step? Do you just reheat the back cover to set it again, or do you need to apply your own glue? Similarly for the power flex. You mention you need to pry past the glue, does this indicate it also needs to be glued back into place?
Willem-Frederick ter Haar - Antwoord
You have to add an adhesive on the edges of the back cover. Don't apply heat from the heat blower
clinton opara - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 2,236
