Ga door naar hoofdinhoud
  1. Remove back cover. Remove back cover. Remove back cover.
    • Remove back cover.
  2. Remove small signal cable.
    • Remove small signal cable.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Twist off those nine screws and remove the bracket. Twist off those nine screws and remove the bracket.
    • Twist off those nine screws and remove the bracket.
  5. There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly. There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly. There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly.
    • There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sophia
41.770 Reputatie
62 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 9
Altijd: 1,529
