Ga door naar hoofdinhoud
Huawei Phone p7 Back Cover Replacement
Wat je nodig hebt
  1. Huawei Phone p7 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Heat to melt the adhesive sticker under the back cover.
  2. Huawei Phone p7 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Place the suction cup and pull to open a gap between the back cover and the body.And then insert into the guitar pick and slide to cut the sticker.
    • Attention: Be careful with the bottom side because there is the battery flex cable.
  3. Huawei Phone p7 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover.
  4. Huawei Phone p7 Back Cover Replacement: stap 4, afbeelding 1 van 1
    • And you can replace with the new back cover.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sophia
43.810 Reputatie
62 handleidingen geschreven
Één opmerking
Is the nfc sensor in the back plate, because i broke the glass and i can see some antennas through the holes. And i think the exposure killed my nfc.
Yoran - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 11,513
