Ga door naar hoofdinhoud
Huawei P9 Lite Rear Camera Replacement
Wat je nodig hebt
  1. Huawei P9 Lite Rear Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 Huawei P9 Lite Rear Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Rear Camera Replacement: stap 3, afbeelding 1 van 1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Rear Camera Replacement, Motherboard Shield: stap 4, afbeelding 1 van 1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Rear Camera Replacement: stap 5, afbeelding 1 van 2 Huawei P9 Lite Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  6. Huawei P9 Lite Rear Camera Replacement, Rear Camera: stap 6, afbeelding 1 van 2 Huawei P9 Lite Rear Camera Replacement, Rear Camera: stap 6, afbeelding 2 van 2
    • Release the rear camera connector.
    • Take the camera out of its recess.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
117.588 Reputatie
188 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
2 opmerkingen
So, i ordered some replacement parts for my huawei p9 lite(Main camera, front camera, usb board), Everything i replaced is working, except for the main camera, the new main camera isn’t working, because when i open my camera app it immediately closes, snapchat shows me an error that says: Snapchat was unable to open the camera app. I made sure that the new main camera isn’t working for some reason, because when i put my original camera back in, everything works, including the new front camera). Am i missing something, could it be a hardware problem or a software problem? Please help, i need advices quick. Thanks.
Zygis Bugenis - Antwoord
My mobile phon p9 lite camera removed without strip how to adjust camera in lens??
junaid ali jan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,377
