Ga door naar hoofdinhoud
Huawei P9 Lite Front Camera Replacement
Wat je nodig hebt
  1. Huawei P9 Lite Front Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Front Camera Replacement: stap 2, afbeelding 1 van 1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Front Camera Replacement: stap 3, afbeelding 1 van 1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Front Camera Replacement, Motherboard Shield: stap 4, afbeelding 1 van 1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Front Camera Replacement: stap 5, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement: stap 5, afbeelding 2 van 2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  6. Huawei P9 Lite Front Camera Replacement, Motherboard: stap 6, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the SIM card tray.
  7. Huawei P9 Lite Front Camera Replacement: stap 7, afbeelding 1 van 3 Huawei P9 Lite Front Camera Replacement: stap 7, afbeelding 2 van 3 Huawei P9 Lite Front Camera Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the motherboard flex, the battery flex and the antenna cable.
  8. Huawei P9 Lite Front Camera Replacement: stap 8, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the display flex and the power and volume button cable.
  9. Huawei P9 Lite Front Camera Replacement: stap 9, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement: stap 9, afbeelding 2 van 2
    • Unplug the rear camera and the headphone jack.
  10. Huawei P9 Lite Front Camera Replacement: stap 10, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement: stap 10, afbeelding 2 van 2
    • Take the camera and the headphone jack out of their recesses.
  11. Huawei P9 Lite Front Camera Replacement: stap 11, afbeelding 1 van 3 Huawei P9 Lite Front Camera Replacement: stap 11, afbeelding 2 van 3 Huawei P9 Lite Front Camera Replacement: stap 11, afbeelding 3 van 3
    • Use a spudger to lift the motherboard carefully.
    • Remove the motherboard assembly.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
  12. Huawei P9 Lite Front Camera Replacement, Front Camera: stap 12, afbeelding 1 van 2 Huawei P9 Lite Front Camera Replacement, Front Camera: stap 12, afbeelding 2 van 2
    • Disconnect the front camera flex from the motherboard.
    • Flip the motherboard over and thread the flex cable through the opening and take the camera away.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
119.540 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.093 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 3,816
