Ga door naar hoofdinhoud
Huawei P9 Headphone Jack Replacement
Wat je nodig hebt
  1. Huawei P9 Headphone Jack Replacement, Back Cover: stap 1, afbeelding 1 van 3 Huawei P9 Headphone Jack Replacement, Back Cover: stap 1, afbeelding 2 van 3 Huawei P9 Headphone Jack Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Headphone Jack Replacement: stap 2, afbeelding 1 van 2 Huawei P9 Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: stap 3, afbeelding 1 van 2 Huawei P9 Headphone Jack Replacement, Fingerprint sensor: stap 3, afbeelding 2 van 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 1 van 3 Huawei P9 Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 2 van 3 Huawei P9 Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 3 van 3
    • Remove the water indicator on top of the screw.
    • Undo the two Phillips #00 screws.
    • Remove metal bracket (mind the adhesive underneath).
  5. Huawei P9 Headphone Jack Replacement: stap 5, afbeelding 1 van 2 Huawei P9 Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the flex cable and remove the headphone jack.
    • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
128.608 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.144 handleidingen geschreven
1Gids Commentaar
questo procedimento funziona anche con il modello p9 plus? grazie per l’attenzione
abcde181 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 6,239
