Inleiding
This guide will show you how to remove the Front and Rear Cameras for the Huawei P8 Lite.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Spudger$2.99
Using the Spudger, begin by removing both of the SIM slots from the side of the device.
Gereedschap gebruikt in deze stap:T5 Torx Screwdriver$9.99
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
3 andere personen hebben deze handleiding voltooid.
