Inleiding
If your Huawei P8 Lite won't hold a charge you can use this guide to replace the worn-out battery without removing the complete motherboard.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Onderdelen
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
To reassemble your device, follow these instructions in reverse order and apply new adhesive strips where necessary.
56 andere personen hebben deze handleiding voltooid.
10 Opmerkingen
Très bon tuto ! Merci beaucoup :-)
ps : j’ai galéré a décollé la batterie
Hat wunderbar funktioniert! Nun läuft mein P8 Lite wieder!
One thing to be careful of that I just did, and screwed up my nieces phone.
You see that black square hole in the aluminium chassis under the battery? Yeah be very very careful when sticking your prying tool under the battery. The LCD us right behind it. Try and stay very far away from those holes in the chassis when you do your prying.
Her screen now has Horizontal and vertical lines right across the centre of the screen.
Sigh.
Super Anleitung, Danke kann ich weiter empfehlen!
