Ga door naar hoofdinhoud
Huawei P20 Camera Lens Replacement
Wat je nodig hebt
    • If you have any questions, feel free to ask them!
Conclusie
5 andere personen hebben deze handleiding voltooid.
Pieter
494 Reputatie
1 Handleiding geschreven
5 opmerkingen
Thanks, you helpt me well with this one!
Kristof Ven - Antwoord
Did this step by step, making sure not to touch the lense. Although, quality of photos are worse than before for some reason
Cole VHelm - Antwoord
Maybe the new lens is of a lower quality?
Pieter -
My lens hasn't broken it just has a smudge on the inside, can you do this and then use the same glue to put the lens back on. Or do you still recommend replacing the entire lens?
Luke Hardy - Antwoord
Hi Luke, Sorry for the late response. I had not seen your reply. It’s definitely going to be hard if you want to remove the glass in one piece.
Please let us know if it worked out for you. Good luck
Pieter -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 10,096
