Ga door naar hoofdinhoud
Huawei P10 Lite Rear Camera Replacement
Wat je nodig hebt
  1. Huawei P10 Lite Rear Camera Replacement, Back cover: stap 1, afbeelding 1 van 3 Huawei P10 Lite Rear Camera Replacement, Back cover: stap 1, afbeelding 2 van 3 Huawei P10 Lite Rear Camera Replacement, Back cover: stap 1, afbeelding 3 van 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Rear Camera Replacement: stap 2, afbeelding 1 van 3 Huawei P10 Lite Rear Camera Replacement: stap 2, afbeelding 2 van 3 Huawei P10 Lite Rear Camera Replacement: stap 2, afbeelding 3 van 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Rear Camera Replacement: stap 3, afbeelding 1 van 2 Huawei P10 Lite Rear Camera Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Rear Camera Replacement: stap 4, afbeelding 1 van 2 Huawei P10 Lite Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Rear Camera Replacement, Battery Disconnection: stap 5, afbeelding 1 van 3 Huawei P10 Lite Rear Camera Replacement, Battery Disconnection: stap 5, afbeelding 2 van 3 Huawei P10 Lite Rear Camera Replacement, Battery Disconnection: stap 5, afbeelding 3 van 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Rear Camera Replacement, Rear Camera: stap 6, afbeelding 1 van 2 Huawei P10 Lite Rear Camera Replacement, Rear Camera: stap 6, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the rear camera flex cable.
    • Remove the rear camera.
Conclusie
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Één andere persoon heeft deze handleiding voltooid.
Dominik Schnabelrauch
229.572 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.465 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 2,222
