Ga door naar hoofdinhoud
Huawei P10 Lite Headphone Jack Replacement
Wat je nodig hebt
  1. Huawei P10 Lite Headphone Jack Replacement, Back cover: stap 1, afbeelding 1 van 3 Huawei P10 Lite Headphone Jack Replacement, Back cover: stap 1, afbeelding 2 van 3 Huawei P10 Lite Headphone Jack Replacement, Back cover: stap 1, afbeelding 3 van 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Headphone Jack Replacement: stap 2, afbeelding 1 van 3 Huawei P10 Lite Headphone Jack Replacement: stap 2, afbeelding 2 van 3 Huawei P10 Lite Headphone Jack Replacement: stap 2, afbeelding 3 van 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Headphone Jack Replacement: stap 3, afbeelding 1 van 2 Huawei P10 Lite Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Huawei P10 Lite Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: stap 5, afbeelding 1 van 3 Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: stap 5, afbeelding 2 van 3 Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: stap 5, afbeelding 3 van 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: stap 6, afbeelding 1 van 2 Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: stap 6, afbeelding 2 van 2
    • Use the flat end of a spuder to disconnect the headphone jack flex cable.
    • Altough the headphone jack is not glued to the mid frame it is a little bit tucked in its bracket. Be careful not to damage it during the removal.
    • Remove the headphone jack.
Conclusie
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
229.572 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.465 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 18
Altijd: 3,579
