Ga door naar hoofdinhoud
Inleiding
Use this guide to replace the front facing camera in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. Huawei P10 Front Facing Camera Replacement, Back Cover: stap 1, afbeelding 1 van 3 Huawei P10 Front Facing Camera Replacement, Back Cover: stap 1, afbeelding 2 van 3 Huawei P10 Front Facing Camera Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Front Facing Camera Replacement: stap 2, afbeelding 1 van 3 Huawei P10 Front Facing Camera Replacement: stap 2, afbeelding 2 van 3 Huawei P10 Front Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Front Facing Camera Replacement: stap 3, afbeelding 1 van 2 Huawei P10 Front Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Front Facing Camera Replacement, Battery disconnect: stap 4, afbeelding 1 van 3 Huawei P10 Front Facing Camera Replacement, Battery disconnect: stap 4, afbeelding 2 van 3 Huawei P10 Front Facing Camera Replacement, Battery disconnect: stap 4, afbeelding 3 van 3
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 1 van 3 Huawei P10 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 2 van 3 Huawei P10 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 3 van 3
    • Use tweezers to carefully loosen the bottom end of the adhesive strip, that holds down the flex connector of the front facing camera.
    • Use a spudger to disconnect the flex cable of the front facing camera.
    • Carefully remove the front facing camera.
Conclusie
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
129.906 Reputatie
534 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
15.081 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 819
