Ga door naar hoofdinhoud
Huawei MediaPad S7-301u Front Camera Replacement
Wat je nodig hebt
  1. Huawei MediaPad S7-301u Front Camera Replacement, Battery: stap 1, afbeelding 1 van 3 Huawei MediaPad S7-301u Front Camera Replacement, Battery: stap 1, afbeelding 2 van 3 Huawei MediaPad S7-301u Front Camera Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Front Camera Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Front Camera Replacement: stap 3, afbeelding 1 van 3 Huawei MediaPad S7-301u Front Camera Replacement: stap 3, afbeelding 2 van 3 Huawei MediaPad S7-301u Front Camera Replacement: stap 3, afbeelding 3 van 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Front Camera Replacement: stap 4, afbeelding 1 van 3 Huawei MediaPad S7-301u Front Camera Replacement: stap 4, afbeelding 2 van 3 Huawei MediaPad S7-301u Front Camera Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: stap 5, afbeelding 1 van 3 Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: stap 5, afbeelding 2 van 3 Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Front Camera Replacement: stap 6, afbeelding 1 van 3 Huawei MediaPad S7-301u Front Camera Replacement: stap 6, afbeelding 2 van 3 Huawei MediaPad S7-301u Front Camera Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Front Camera Replacement: stap 7, afbeelding 1 van 2 Huawei MediaPad S7-301u Front Camera Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Front Camera Replacement, Front Camera: stap 8, afbeelding 1 van 1
    • Once the battery is removed, remove the front facing camera from the socket located on the top left of the tablet.
  9. Huawei MediaPad S7-301u Front Camera Replacement: stap 9, afbeelding 1 van 2 Huawei MediaPad S7-301u Front Camera Replacement: stap 9, afbeelding 2 van 2
    Koop
    • Gently unclip the camera from the motherboard using your fingers or a pair tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chenet Valmy
213 Reputatie
1 Handleiding geschreven
USF Tampa, Team S11-G5, Passmore Fall 2017 Lid van USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 373
