Ga door naar hoofdinhoud
Huawei MediaPad S7-301u Battery Replacement
Wat je nodig hebt
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Huawei MediaPad S7-301u Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Huawei MediaPad S7-301u Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: stap 3, afbeelding 1 van 3 Huawei MediaPad S7-301u Battery Replacement: stap 3, afbeelding 2 van 3 Huawei MediaPad S7-301u Battery Replacement: stap 3, afbeelding 3 van 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: stap 4, afbeelding 1 van 3 Huawei MediaPad S7-301u Battery Replacement: stap 4, afbeelding 2 van 3 Huawei MediaPad S7-301u Battery Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Miguel Lugo
598 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G5, Passmore Fall 2017 Lid van USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Leden
8 handleidingen geschreven
Één opmerking
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 7,012
