Inleiding
Unlike most tablets, the Huawei MediaPad M2 10.0 has a display assembly that is easy to remove, a big positive when looking at repair. The battery is incredibly difficult to remove, however, giving the tablet a 7 out of 10 on the repairability scale.
  1. Front/back reference shots.
    • Front/back reference shots.
  2. Simple plastic clips make opening easy.
    • Simple plastic clips make opening easy.
    • The display cable has enough slack to lay the display aside to work on the interior.
    • Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
      • Home button/fingerprint reader is easily removed and replaced.
    • The battery is glued to the rear case by very strong adhesive.
    • Heat, adhesive removal fluid, and much prying, the battery is removed.
      • Frustrating that an inevitable repair/replacement would be this hard, but at least it isn't blocking other components' replacement.
    • The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious.
    • Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
      • SIM tray can be removed while the device is sealed, obviously.
    • The final components out of the rear case are fairly modular:
      • SIM reader and vibrator assembly
      • Headphone jack and button cable assembly
      • Front and rear facing cameras
      • Motherboard, unfortunately has a soldered-on charging port. That means a more expensive repair for a common failure point.
    • The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
      • The display is easily removed from the simple clips holding it to the body, simplifying repairs.
      • Most components are modular and not overly complex.
      • The battery is extremely difficult to remove, even with heat and prying.
      • The charging port is soldered to the motherboard, making replacement of this high-use component expensive.
      • Manufacturer does not provide user-accessible repair documentation.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Andrew Optimus Goldberg
399.384 Reputatie
412 handleidingen geschreven
iFixit Lid van iFixit
Community
108 Leden
7.549 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 10
Afgelopen 7 Dagen: 53
Afgelopen 30 Dagen: 246
Altijd: 4,186
