Inleiding
The warranty will be voided with any battery replacement and the display is complicated to replace, therefore the Huawei Mate 8 earns a 6 out of 10 on the repairability scale.
Gereedschap
Onderdelen
Geen onderdelen nodig.
There is a tamper evident sticker on the screw that holds the bracket securing the battery connectors.
There is a pull tab that makes adhesive removal easier. These tabs can easily be torn though.
In addition to the pull tab adhesive, the battery is also secured by adhesive near the bottom. This adhesive has no tab and requires heat and aggressive prying to separate.
Nine Phillips screws secure the motherboard to the rear case.
Two Phillips screws secure the daughterboard to the rear case.
Two Phillips screws and a small amount of adhesive hold the speaker to the rear case. Light prying is required after screw removal.
The front-facing camera is held in place by pressure from the motherboard and by tabs in the rear case. It is easy to remove the camera after the motherboard is removed.
The rear-facing camera is secured in place by the motherboard. It is easy to remove after the motherboard is removed.
The earpiece speaker is held in place by light adhesive and can be removed by prying.
The vibration motor is held in place by light adhesive and can be removed by prying.
The Huawei Mate 8 earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
Many components are modular and can be individually replaced.
Opening the phone requires only a Torx screwdriver and a prying tool (No adhesive holding it together).
The battery does have a pull tab adhesive strip, but there is a second adhesive strip that does not have a tab.
A tamper evident sticker must be removed when disconnecting the battery.
LCD Display is integrated into the front case. While the replacement process is pretty straightforward, you’ll still need to pick every component off the frame and likely pay more to replace this non-modular component.
Manufacturer does not provide user-accessible repair documentation.
3 andere personen hebben deze handleiding voltooid.
