Ga door naar hoofdinhoud
Huawei Mate 8 Loudspeaker Replacement
Wat je nodig hebt
  1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: stap 1, afbeelding 1 van 2 Huawei Mate 8 Loudspeaker Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Loudspeaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Loudspeaker Replacement: stap 3, afbeelding 1 van 2 Huawei Mate 8 Loudspeaker Replacement: stap 3, afbeelding 2 van 2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Loudspeaker Replacement: stap 4, afbeelding 1 van 3 Huawei Mate 8 Loudspeaker Replacement: stap 4, afbeelding 2 van 3 Huawei Mate 8 Loudspeaker Replacement: stap 4, afbeelding 3 van 3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: stap 5, afbeelding 1 van 3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: stap 5, afbeelding 2 van 3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: stap 5, afbeelding 3 van 3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Loudspeaker Replacement: stap 6, afbeelding 1 van 3 Huawei Mate 8 Loudspeaker Replacement: stap 6, afbeelding 2 van 3 Huawei Mate 8 Loudspeaker Replacement: stap 6, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Loudspeaker Replacement: stap 7, afbeelding 1 van 1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Loudspeaker Replacement: stap 8, afbeelding 1 van 2 Huawei Mate 8 Loudspeaker Replacement: stap 8, afbeelding 2 van 2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Loudspeaker Replacement: stap 9, afbeelding 1 van 1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Loudspeaker Replacement, Charging Board: stap 10, afbeelding 1 van 3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: stap 10, afbeelding 2 van 3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: stap 10, afbeelding 3 van 3
    • Remove the two Phillips #00 screws.
    • Use the flat end a spudger to disconnect the loudspeaker flex connector.
    • Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the daughterboard.
  11. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: stap 11, afbeelding 1 van 3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: stap 11, afbeelding 2 van 3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: stap 11, afbeelding 3 van 3
    • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
    • Remove the loudspeaker.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Theo Mat
12.897 Reputatie
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 1,061
