Ga door naar hoofdinhoud
Huawei Mate 10 Pro Camera Assembly Replacement
Wat je nodig hebt
  1. Huawei Mate 10 Pro Camera Assembly Replacement, SIM Card Tray: stap 1, afbeelding 1 van 2 Huawei Mate 10 Pro Camera Assembly Replacement, SIM Card Tray: stap 1, afbeelding 2 van 2
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
  2. Huawei Mate 10 Pro Camera Assembly Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  3. Huawei Mate 10 Pro Camera Assembly Replacement: stap 3, afbeelding 1 van 3 Huawei Mate 10 Pro Camera Assembly Replacement: stap 3, afbeelding 2 van 3 Huawei Mate 10 Pro Camera Assembly Replacement: stap 3, afbeelding 3 van 3
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  4. Huawei Mate 10 Pro Camera Assembly Replacement: stap 4, afbeelding 1 van 2 Huawei Mate 10 Pro Camera Assembly Replacement: stap 4, afbeelding 2 van 2
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  5. Huawei Mate 10 Pro Camera Assembly Replacement: stap 5, afbeelding 1 van 2 Huawei Mate 10 Pro Camera Assembly Replacement: stap 5, afbeelding 2 van 2
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  6. Huawei Mate 10 Pro Camera Assembly Replacement, Motherboard: stap 6, afbeelding 1 van 2 Huawei Mate 10 Pro Camera Assembly Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Unscrew screws on black cover and remove using tweezers to leverage.
  7. Huawei Mate 10 Pro Camera Assembly Replacement: stap 7, afbeelding 1 van 2 Huawei Mate 10 Pro Camera Assembly Replacement: stap 7, afbeelding 2 van 2
    • Pop off gold covers.
  8. Huawei Mate 10 Pro Camera Assembly Replacement: stap 8, afbeelding 1 van 3 Huawei Mate 10 Pro Camera Assembly Replacement: stap 8, afbeelding 2 van 3 Huawei Mate 10 Pro Camera Assembly Replacement: stap 8, afbeelding 3 van 3
    • Disconnect wires attached to motherboard assembly.
  9. Huawei Mate 10 Pro Camera Assembly Replacement: stap 9, afbeelding 1 van 2 Huawei Mate 10 Pro Camera Assembly Replacement: stap 9, afbeelding 2 van 2
    • Wedge tweezers under motherboard and leverage assembly to pop assembly out.
  10. Huawei Mate 10 Pro Camera Assembly Replacement: stap 10, afbeelding 1 van 1
    • Separate camera assembly by popping it out, if only the motherboard is needed.
  11. Huawei Mate 10 Pro Camera Assembly Replacement, Camera Assembly: stap 11, afbeelding 1 van 3 Huawei Mate 10 Pro Camera Assembly Replacement, Camera Assembly: stap 11, afbeelding 2 van 3 Huawei Mate 10 Pro Camera Assembly Replacement, Camera Assembly: stap 11, afbeelding 3 van 3
    • On the backside of the motherboard assembly, detach the camera assembly from the motherboard.
Conclusie
Annabelle Harding
433 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-5, Harley Spring 2022 Lid van IUPUI, Team 3-5, Harley Spring 2022
IUPUI-HARLEY-S22S3G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 268
