Ga door naar hoofdinhoud
Huawei Mate 10 Pro Back Cover Replacement
Wat je nodig hebt
  1. Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: stap 1, afbeelding 1 van 2 Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: stap 1, afbeelding 2 van 2
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
  2. Huawei Mate 10 Pro Back Cover Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  3. Huawei Mate 10 Pro Back Cover Replacement: stap 3, afbeelding 1 van 3 Huawei Mate 10 Pro Back Cover Replacement: stap 3, afbeelding 2 van 3 Huawei Mate 10 Pro Back Cover Replacement: stap 3, afbeelding 3 van 3
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  4. Huawei Mate 10 Pro Back Cover Replacement: stap 4, afbeelding 1 van 2 Huawei Mate 10 Pro Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  5. Huawei Mate 10 Pro Back Cover Replacement: stap 5, afbeelding 1 van 2 Huawei Mate 10 Pro Back Cover Replacement: stap 5, afbeelding 2 van 2
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
172.192 Reputatie
676 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
17.566 handleidingen geschreven
2 opmerkingen
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Luis Liberato - Antwoord
Thanks for good work you do
amoudi Guide - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 126
Altijd: 15,133
