Ga door naar hoofdinhoud
Huawei Ascend XT Speaker Replacement
Wat je nodig hebt
  1. Huawei Ascend XT Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Huawei Ascend XT Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Use the 0.8 Sim driver bit to remove the SIM tray by inserting it into the hole on the side of the device.
    • Once the hole is pressed in firm, the SIM tray will pop out. This allows you to grab it and extract it from the device.
  2. Huawei Ascend XT Speaker Replacement: stap 2, afbeelding 1 van 2 Huawei Ascend XT Speaker Replacement: stap 2, afbeelding 2 van 2
    • Make a thumbs-up and use it to grip the plastic opening tool with the flat end pointing in the direction of your thumb.
    • Place the flat end of the opening tool slightly inside the charging port and place your thumb on the back of the phone.
    • Press into the phone with your thumb while pulling the opening tool back with your fist to begin prying the back off.
  3. Huawei Ascend XT Speaker Replacement: stap 3, afbeelding 1 van 2 Huawei Ascend XT Speaker Replacement: stap 3, afbeelding 2 van 2
    • Slide the flat end of the spudger along the edge of the device, prying off the back cover.
    • Carefully remove the back cover. This may be difficult due to glue on the inside.
  4. Huawei Ascend XT Speaker Replacement: stap 4, afbeelding 1 van 2 Huawei Ascend XT Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the seven screws using a Phillips #00 screwdriver.
  5. Huawei Ascend XT Speaker Replacement: stap 5, afbeelding 1 van 2 Huawei Ascend XT Speaker Replacement: stap 5, afbeelding 2 van 2
    • Use the spudger to carefully pull off the speaker assembly.
    • Once off you will replace it with your new speaker assembly.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 223
