Ga door naar hoofdinhoud
Inleiding
It is a straightforward guide showing the steps towards removing the front camera. Remember to be careful during the disassembling. The parts can break easily.
  1. Flip the device over so that the back of the phone is facing you and the screen is against your palm.
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Locate the slit at the bottom of the back cover.
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Lift the back cover off the phone.
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Find the indented notch at the base of the battery. Lift the battery out of the phone with your fingers by pressing forward and lifting upward. Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. After removing the battery, remove the screws using a T6 screwdriver. There are eleven screws that hold the middle cover to the rest of the phone.
    • After removing the battery, remove the screws using a T6 screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
    • The screw that is marked by the orange circle is covered by a white dot.
  6. After all the screws are removed, use your fingers to remove the lower section of the middle cover. Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath. Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
    • After all the screws are removed, use your fingers to remove the lower section of the middle cover.
    • Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
  7. Begin working your way around the sides of the cover plate, unsnapping it gently. The middle cover is a thin piece of plastic with the external speaker inside of it. Be gentle as you remove circuit cover. The parts might break if you are too forceful.
    • Begin working your way around the sides of the cover plate, unsnapping it gently.
    • The middle cover is a thin piece of plastic with the external speaker inside of it.
    • Be gentle as you remove circuit cover. The parts might break if you are too forceful.
  8. The middle covers are removed. The antenna is a thin white wire that connects to the circuit board in two locations.
    • The middle covers are removed.
    • The antenna is a thin white wire that connects to the circuit board in two locations.
  9. Lift gently at each connector of the white wire to disconnect the antenna from the port. Lift gently at each connector of the white wire to disconnect the antenna from the port.
    • Lift gently at each connector of the white wire to disconnect the antenna from the port.
  10. Use a plastic spudger or your fingers to gently pry up the four flex cables from the main board. Use a plastic spudger or your fingers to gently pry up the four flex cables from the main board. Use a plastic spudger or your fingers to gently pry up the four flex cables from the main board.
    • Use a plastic spudger or your fingers to gently pry up the four flex cables from the main board.
  11. With the back of the phone facing you, there will be a small black clip on the left side holding the main board in place. Gently pry up near the small black clip with your fingers or a plastic spudger to detach  the main board.
    • With the back of the phone facing you, there will be a small black clip on the left side holding the main board in place.
    • Gently pry up near the small black clip with your fingers or a plastic spudger to detach the main board.
  12. With the main board facing away from you, the front camera is on the top right corner. There is a silver connector and a black flex cable attached to the front camera.
    • With the main board facing away from you, the front camera is on the top right corner.
    • There is a silver connector and a black flex cable attached to the front camera.
  13. Using the small pliers, disconnect the front camera's flex cable from the main board.
    • Using the small pliers, disconnect the front camera's flex cable from the main board.
  14. Once the flex cable is disconnected, completely remove the front camera off the main board.
    • Once the flex cable is disconnected, completely remove the front camera off the main board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jaie Hillery
1.625 Reputatie
10 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Winter 2016 Lid van USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Leden
22 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 353
