Ga door naar hoofdinhoud
Hp Pavilion dv6-2155dx Optical Drive Replacement
Wat je nodig hebt
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: stap 1, afbeelding 2 van 2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: stap 3, afbeelding 1 van 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: stap 3, afbeelding 2 van 2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: stap 4, afbeelding 1 van 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: stap 4, afbeelding 2 van 2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
Conclusie
Joseph Sanda
522 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 832
