Inleiding
If your mac is having trouble recognizing a replacement battery or other components, you may need to repair your main disk permissions. Follow this guide as a first step in troubleshooting.
You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
Or you can take the shortcut and use Spotlight!
Once opened, you should be presented with a window that looks like this.
You will want to select the name of your Mac OS X Startup disk in the left column.
After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
The First Aid heading is what you will want to be under.
Click on the Verify Disk Permissions, starting the process.
After verifying the disk permissions, go ahead and select repair disk permissions to start that process.
During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
What do you for if not sll the permissions are fixed,?
Twiddle your thumbs maybe? That seems like a good idea.
Mike -
You should definitely get a cat! :) -suzanne
Looks like as of Catalina at least these instructions are a little outdated as the Disk Utility UI has changed such that several referenced buttons don’t really exist. Should probably update for both Catalina and Big Sur, which I’m guessing is even more different. Thanks!
Congrats! You successfully repaired your disk permissions!
52 andere personen hebben deze handleiding voltooid.
2 opmerkingen
verify disk does not come up after I enter fix and the procedure stops, I am running high sierra 10.13.6, Help please
Did anyone help you? I'm running through the same issues?
1.21 gigawatts! 1.21 gigawatts. Great Scott!
Doc Brown - Antwoord
