Ga door naar hoofdinhoud
How to verify and repair Mac OS X Disk Permissions
  1. How to verify and repair Mac OS X Disk Permissions, How to verify and repair Mac OS X Disk Permissions: stap 1, afbeelding 1 van 2 How to verify and repair Mac OS X Disk Permissions, How to verify and repair Mac OS X Disk Permissions: stap 1, afbeelding 2 van 2
    • You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
    • Or you can take the shortcut and use Spotlight!
  2. How to verify and repair Mac OS X Disk Permissions: stap 2, afbeelding 1 van 2 How to verify and repair Mac OS X Disk Permissions: stap 2, afbeelding 2 van 2
    • Once opened, you should be presented with a window that looks like this.
    • You will want to select the name of your Mac OS X Startup disk in the left column.
    • After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
    • The First Aid heading is what you will want to be under.
    • Click on the Verify Disk Permissions, starting the process.
  3. How to verify and repair Mac OS X Disk Permissions: stap 3, afbeelding 1 van 2 How to verify and repair Mac OS X Disk Permissions: stap 3, afbeelding 2 van 2
    • This usually will take anywhere from 3 minutes to 15 minutes. The best thing to do is to wait.
    • As time progresses, you will see information pop up in the window highlighted.
    • This is good, it means that it is seeing the problems that may be keeping your computer from running well.
  4. How to verify and repair Mac OS X Disk Permissions: stap 4, afbeelding 1 van 2 How to verify and repair Mac OS X Disk Permissions: stap 4, afbeelding 2 van 2
    • After verifying the disk permissions, go ahead and select repair disk permissions to start that process.
    • During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
Conclusie
Congrats! You successfully repaired your disk permissions!
54 andere personen hebben deze handleiding voltooid.
Mike
14.455 Reputatie
3 handleidingen geschreven
2Gids Commentaar
verify disk does not come up after I enter fix and the procedure stops, I am running high sierra 10.13.6, Help please
gene kaz - Antwoord
Did anyone help you? I'm running through the same issues?
Marco Saavedra -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 126
Altijd: 16,403
