Inleiding
The included emergency jack should only be used for changing wheels, and is rated for lifting 950 kg.
Warning: Using the emergency jack can be dangerous due its inability to evenly distribute the vehicle’s weight. Additionally, the placement of the emergency jack should correspond with the jack supports underneath the vehicle to prevent slippage of the jack.
Open the boot, turn over the floor and retrieve the jack crank and the tire iron.
Open the compartment where the jack is located.
Using the jack crank, turn the jack axle counter clockwise to unsecure it from the compartment and pull it out.
There are 4 u-shaped jack supports underneath the car, located next to each wheel.
Turn the jack axle by hand until the support slot of the jack can be placed on the support.
Place the jack crank on the jack axle, and using the tire iron, turn clockwise.
Stop cranking when the wheel is high enough from the ground to be replaced.
Follow these instructions in reverse order to lower the car and put the tools back.
Één andere persoon heeft deze handleiding voltooid.
