Ga door naar hoofdinhoud
How to update Kali
    • Press Ctrl + Alt + T to open the Terminal Interface.
    • To update and upgrade Kali enter the following command: sudo apt update -y && sudo apt upgrade -y
    • If you asked to restart services during the upgrades, choose Yes
    • Once the updates and upgrades are complete some of the packages won't be required. You can remove those packages with the command: sudo apt autoremove -y
    • This will allow your Kali Linux machine to run smoothly and will free up necessary storage.
Conclusie
In the event that you don't have the latest release of Kali Linux, or didn't install it, you're going to want to use the following command
sudo apt update && sudo dist-upgrade -y
Be cautious, as this is the equivalent a major Windows Update and can mess up a system that you have been using for a while.
19 andere personen hebben deze handleiding voltooid.
Jacob Mehnert
46.665 Reputatie
51 handleidingen geschreven
iFanatics Lid van iFanatics
Community
67 Leden
223 handleidingen geschreven
4Gids Commentaar
Hello / Hallo - many thanks / vielen Dank... Top :) .... Regards / Grüße
Marco Werner - Antwoord Deel
En la versión de kali 2024, al realizar el dist-upgrade, me dañó la instalación.
Ejecuté sudo apt upgrade -y y me actualizó sin problemas.
Removí los programas con la instrucción supo apt autoremove -y
Mario Enrique Salguero Juárez - Antwoord Deel
Gracias asi es que actualiza esta version
Juan Mario Paba Gomez - Deel
schreibfehler bei upggrade
BossderBosse - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 88
Afgelopen 30 dagen: 373
Altijd: 99,746
