Ga door naar hoofdinhoud
How to unpair a Mitsubishi MMCS NR-242 Map SD Card
Wat je nodig hebt
  1. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Identify your Revision: stap 1, afbeelding 1 van 1
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • You need either a Version W-11 or W-12. In this case the Version Number is W-12, so we can proceed.
  2. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Download the Unlock Binary: stap 2, afbeelding 1 van 1
    • You can download the Binary at this site.
    • Download the Binary.
    • Extract the NK.BIN file from the W12_MAP_UNLOCKER.rar archive using 7-Zip.
  3. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Move the File: stap 3, afbeelding 1 van 1
    • The SD card needs to be formatted to FAT32. If it’s not already formatted to FAT32 and you don’t know how to do it, you can take a look at this guide.
    • Copy the NK.BIN file to the root directory of the SD Card.
  4. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: stap 4, afbeelding 1 van 2 How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: stap 4, afbeelding 2 van 2
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  5. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: stap 5, afbeelding 1 van 2 How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: stap 5, afbeelding 2 van 2
    • Remove the SD Cards from both the MAP and USER-Slots.
    • Insert the new SD Card into the USER-Slot.
    • Close the display by pressing the Open-Button again.
  6. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Reboot the Unit: stap 6, afbeelding 1 van 1
    • Long press both the NAVI MENU and AUDIO-Buttons to reboot into unlocker mode.
  7. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Insert the paired SD Card: stap 7, afbeelding 1 van 1
    • Open the display again by following the instructions in Step 4
    • Insert the paired SD Card into the MAP-Slot.
    • Wait 5-10 Seconds for the unpairing process to be completed before removing it again.
  8. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Return the SD Cards: stap 8, afbeelding 1 van 1
    • Return the SD Cards you removed in Step 5 back to their respective Slots.
  9. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Exit the Unlocking Mode: stap 9, afbeelding 1 van 1
    • Long press both the NAVI MENU and AUDIO-Buttons again to reboot back into standard mode.
Conclusie
Drive safe!
Sebastian
23.881 Reputatie
65 handleidingen geschreven
German Translators Lid van German Translators
Community
28 Leden
808 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 71
Altijd: 1,058
