Ga door naar hoofdinhoud
How to tighten the Razor A handlebar clamp
  1. How to tighten the Razor A handlebar clamp, How to tighten the Razor A handlebar clamp: stap 1, afbeelding 1 van 1
    • Locate the T-tube clamp. It is in the middle of the steering column.
  2. How to tighten the Razor A handlebar clamp: stap 2, afbeelding 1 van 2 How to tighten the Razor A handlebar clamp: stap 2, afbeelding 2 van 2
    • Open the clamp by pulling the lever away from the scooter.
  3. How to tighten the Razor A handlebar clamp: stap 3, afbeelding 1 van 2 How to tighten the Razor A handlebar clamp: stap 3, afbeelding 2 van 2
    • Locate the screw on the side of clamp.
    • Turn the screw on the side of the clamp by hand in a clockwise direction.
    • Attempt to close the clamp. If the lever is too tight to close, loosen the screw slightly and try again.
    • The T-tube should now be locked in place. If it continues to fall down, repeat the instructions in this guide.
Eindstreep
Jordyn
565 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-13, Amido Fall 2012 Lid van Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 4,118
