Inleiding
This iPhone 8 plus ran out of battery completely, does not turn on because surely the battery level is very low.
With the BAKU adjustable power supply and an adapter for the battery input, we were able to charge the battery.
No sound, just work, few cuts. activate subtitles.
After charging, i have check the battery, charging port and usb cable work correctly. But this was a fault because the charger does not have the same output power in Amp as the BAKU or any power supply can offer.
Wat je nodig hebt
Video-instructies
The battery sometimes can't be charged correctly and need a stable signal at 5V 1A.
Één opmerking
mido mi bataeria con el tester y mide 4,15 , pero no arranca , debe llegar a 4.50 para poder arrancar?
Canalla 1889 - Antwoord
