Wat je nodig hebt
Press the two red buttons of the brew group together and remove the brew group.
Lay the machine on its rearside, with the open frontside looking upwards.
The brewing strainer of the upper piston is fixed with two phillips screws PH2.Turn it out.
With some force, remove the brewing strainer and remove the old sealing ring.
Clean the brewing strainer and what is underneath is fine.
Grease the new sealing ring with food grade silicone grease. Put it on the piston and tighten the brewing sieve again.
The crema valve is hard to recognize. It is covered with a plastic stopper. You can gently remove it with the sharp tip of a cutter.
Underneath is the valve. It consists of a spring and a small piston. Clean everything very well, also the channels. Be very careful.
Plug in the valve again. Screw the brewing strainer tight and attach the two new sealing rings. Grease the sealing rings and the piston barrel thinly with food-grade silicone grease.
Repeat the steps in order to reassemble your device.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
